- 7 Mar 2016
Can anyone suggest a good pump for a cpu gpu loop 360 rad? Would like to keep costs as low as possible. I will be getting a d5 vario but maybe not for a year. Any advice would be great
Honestly, get a pre-owned D5 Vario if you dun have enough budget and be happy with that for a long while...
A good pump can last you for a few builds and will very likely to be the noisiest component of your loop in idle if I have to be honest.
Cool thanks, do you have any recommendations on where to go to get a used pump?
A long time till you have access to members market. AV forums normally have people selling stuff or ebay as mentioned. Im surprised you dont have a few knocking around deFiniLoGy. You normally have a supply of used WC parts.
