Sure.
Download sweetfx2.0 + reshade 1.1 (one download all files combined) - that will give you these files:
Copy all the files except the two readme's and the sweetfx+reshade zip file (6 items)
Paste them into Division directory where the Division.exe is.
Rename the Reshade64.dll to dxgi.dll
Download the Kputt config from here https://sfx.thelazy.net/games/preset/5087/
copy and paste this file into the Sweetfx folder that you moved into Division directory, should look like this
Delete the SweetFX_settings.txt
Rename the new config "SweetFX_settings.txt"
Done, use "scroll lock" in game to toggle on and off
This was the method I used to add SweetFX/Reshade to the beta. (Cheers, Tony) Am I correct to assume I can just follow the same method with the full game and then just copy/paste the contents of the .fx file from the latest version, if it's been updated?
I also recall someone on here had created one, but I can't find the post. Does anyone have a link, please?
