After I built my PC up (spec in sig) back in January I always had a random BSOD crash - Not usually when gaming more when in Firefox or on you tube.
I ignored it the first couple of times thinking/hoping it would not continue but recently it has got the better of me.
Now it almost always happens once and the errors can either be memory management or IRQL and I think have also saw bad service pool - After the system has this BSOD and restarts it is fine for the rest of the period I am using it and there are no issues.
I have done a fresh install of Windows 10 and only saw it happen once so far whilst on you tube in Edge browser.
I am using 16GB of Corsair Vengeance LPX 16 GB (2 x 8 GB) 3000 MHz CL15 XMP 2.0 DDR4 RAM and read a few other people having same issues using this in the same board as me - Z170 Pro so I am going to try lowering the clock rate of the ram and see if that helps any.
Has anyone else had experience with an issue like this in the past? If so what was the cause and fix?
Cheers,
Cheers,
