- 30 Oct 2008
- South
Looks as though a few ferrite clips arrived in the post for me today so we'll see if it makes a difference
A geiger counter? if said vehicle is radioactive![]()
Well, the ferrite clips have made a difference but have not irradiated the issue completely, I'm able to pick up some stronger signalled stations but there are a lot I still can't get until I remove the camera. I'm actually thinking of removing the aerial and sticking it on the back window, maybe keeping it as far apart from the USB cable as I can will help. Or would the fact that the dab aerial will still need to be earthed to the car cause the same problem. Any ideas?
Does it do it when the dashcam runs off it's own battery?
Most of these USB cigar chargers have inverters (DC-DC converters) in them that cause interference on DAB.
So are you sure that it's not the actual unit that plugs into the ciggie lighter that's causing the issue? I'd also try another cable assuming it's just a standard micro usb cable just to eliminate either the cable or the ciggie lighter plugin thingy![]()
