I'd assume that was the case yet Google had input on the 6P's design that had far larger capacities in the end. I was well in for that Nexus 9 until the storage was so heavily gimped.Specs are set by Google surely?
HTC's personal failures tend to be a slightly dodgy initial production run and a poor yet inventive (to a problem easily solved by everyone else) camera
The new M10 looks hideous from the leaks I've seen, if that's the design path they go with the new Nexus..
Talk about going backwards in design, they had a beautiful phone in the M8 which I still use to this day.
I think its good for HTC personally as they're struggling hugely as we all know. My only gripe with them is that they always produce a superb device but there is always ONE con to them all i.e battery capacity, camera sensor size etc. Hopefully they can get it right because I was always annoyed at their Nexus 9 tablet it's low storage capacity.
Faithful owner of the desire and M7 until the 6p came out so I agree in principleI look forward to seeing what they pull out though as I've always maintained that the HTC One was one of their best products years ago and I'm hoping they can repeat that sort of design.
I wouldn't touch a htc so I'll be moving to another brand after the 6p
Same here. Been burned too many times with HTC products and the poor after care.
Buy from Google or amazon so you don't have to deal with htc.
That doesn't protect you from the poor build quality though. I had the HTC One X and HTC One m7 with a total of 9 issues in 4 years.
Hey guys, I'm planning on buying this phone today from Google. Can any of you recommend a tempered glass screen protector that doesn't cover up the proximity sensor? and maybe a usb to c cable (they're out of stock at google -.-)![]()
Search "Minotaur Google Nexus 6P (2015) Tempered Glass Screen Protector " on rainforest.
Not sure about cable
Thanks for the info.Just a heads up, £35 off via Google play store for both 6p and 5x
It's a very close fit - less then .5mm around the edges. Had it about 2 months. No bubbles though I bought 3 as the first one I screwed up the install. I use it with a Tudia Case and its perfect fit. The spigen screen protector for the 6p is terrible - huge gap around the edge and lifts up at the bottom. This one is a far closer fit.What type of fit is this protector? Edge to edge? does it fit well with a case? (I'm thinking about getting the rugged amor case). How long have you had it? Have you noticed any lifting since its first install?
