Powerline adapters - 500Mbps vs 1000/1200Mbps
31 Dec 2006
Is there going to be any real noticeable difference between a 500Mbps vs 1000/1200Mbps adapter in a home environment? I will be using with Virgin Vivid 200, although not sure what my actual speeds are as not moving in until next week. Is paying more for a 'faster' adapter worth it?? I came across the below tests someone did and it would suggest 1000/1200 is a waste of money?
http://www.techpowerup.com/forums/t...-n-vs-wireless-ac-vs-gigabit-ethernet.212628/
That article is far too limited to draw any conclusions.
If you want to have any chance of getting anyway near 200Mbps you're going to need the 1000/1200 adapters.
If you actually want the full speed then find a way to run a cable.
For me the point of having a 200Mbps service is to properly support a number of different simultaneous clients, not just to provide a single machine with a fast connection. If getting the full speed at a particular device is important then be prepared to install some cables.
I posted a thread over the weekend about something similar .. and just a word of advice which I have learnt make sure whatever plugs you go with that they support the gigabit ethernet ports. otherwise you will have no chance of reaching the speeds
Ideally, go for the fastest adapters you can afford. You won't ever see the speeds they're rated at, but you'll still get better results than you would with a lower-rated set.
Build quality and chipset will matter most just like with wireless adapters. So an expensive 500Mbps set may work better than a cheap 1200Mbps set. Powerline modulates and transmits data much in the same way as wireless, only using the electrical wiring as a medium this time, and suffers from the same environmental noise issues that can hinder connection quality.
Not a new build unfortunately, about 20 years old, so no chance of putting new cable in. I was looking at the Solwise AV2 1200, seems to be one of the better adapters out there. I would chance it with wi-fi, but it's a solid house with thick brick walls so not ideal in that sense.
I've used the following over the past few years and these are the results I've had when using LAN:
2.4GHz wireless n (VM SH2) - 3MB/sec
5GHz wireless n (VM SH2) - 5MB/sec
.ac wireless (AC87U) - 35MB/sec
500MB powerline - 8.5MB/sec
1gbps ethernet - 112MB/sec
Network connectivity is something that should never drop, it's unacceptable.
Powerline increases the chance of this, big time.
So does WiFi, do you propose people abandon that too?
Wifi is for mobile devices and things that don't rely on a network connection to work (it doesn't really matter if your BD player loses it's internet - although if it happens when watching GOT via it's Netflix app you may disagree).
Anything fixed that needs connectivity is far better off with wired.
I've given up on homeplugs, and even wireless annoys me for anything that it's not the only option for.
I've wasted far too much of my time trying to get them to work, and found that Homeplugs simply aren't worth the time/effort of trying to get them to work in houses with older wiring (<10mb/s)
My Xbox One streaming 1080p content from Plex on wireless AC, not to mention all the other media streaming services I use, says hi. Oh, and it also maxes out my Vivid 200Mbps connection according to the network test...
Wireless AC and/or Powerline are fine for most people, folks should stop forcing the panacea of wired home networks onto anyone who asks for advice as it's simply unnecessary. Nice and the ideal yes, but unnecessary. Most don't want the disruption of lifting floorboards or channeling walls to run CAT5e when other options are perfectly adequate.
I've got 500mbps adaptors round the house, not lost the connection once in 2 years, top out at 20MB/s (they've got gigabit ports).
Not as good as ethernet but more than good enough.
I've got 5 powerlines dotted around the house (for 3 AP's). It would require an inordinate amount of work to run cat5 around instead.
You know what, I've never had a problem with any of them either. As for their speed, well they max out the 4mb internet connection and that's all that matters.
