No interest in getting a TV for reasons of input lag, motion blur, lack of pixel density etc.
Would preferably be IPS/VA for better viewing angles.
Thanks.
please explain how a 32" monitor has higher pixel density @ 1080p than a 32" 1080p tv?
also input lag is greatly exaggerated. i cannot see input lag on my GT50 which is around 30-40ms. i also game on a monitor with no input lag what so ever and there is no difference.
if i don't put my tv into game mode it's then around 100ms and the lag is noticeable straight away and unplayable.
what i'm trying to say is anything below 40ms is negligible. which a decent tv will be.
Would the curve affect viewing from angles?
curved tv's aren't boomerangs, it's a subtle curve in most circumstances you don't even notice it's curved.
Am I being a snob for NOT wanting a TV?
i would say so.
http://www.hdtvtest.co.uk/news/ue32j6300-201507124139.htm
"Samsung’s highest-ranked 1080p HDTV for 2015"
Measured panel refresh rate 120Hz
Input lag (high-speed camera) 31ms compared to lag-free CRT
Leo Bodnar input lag tester 42ms in [PC] mode
Full 4:4:4 reproduction (PC) Yes, with 60hz signal and [PC] input label
Motion
For a £500 TV, the motion handling on the 32J6300 was outstanding – we honestly didn’t expect Samsung to equip such an affordable set with some of the best motion-enhancing technologies available on the market.
Lovers of black frame insertion (BFI) can activate the tech on the UE32J6300 by switching on [LED Clear Motion] in the [Auto Motion Plus] “Custom” submenu, which improves motion clarity tremendously without incurring interpolation artefacts or soap opera effect (SOE) in 24fps movies. Some image darkening and flicker inevitably ensued due to how BFI works, but the former could be adequately compensated for by cranking up [Backlight] (we measured a max luminance of 150 cd/m2 in full-field white with [LED Clear Motion] engaged), whereas the latter was a non-issue (for us) in most real-life material except during truly bright scenes.
Viewers who demand higher brightness or are particularly sensitive to flicker can also choose to forgo black frame insertion, and use the separate deblur and dejudder controls (again found in the [Auto Motion Plus] “Custom” submenu) to achieve high motion resolution with minimal side effects.
We watched a ton of Wimbledon matches on the 32in Samsung J6300 off the TV’s internal Freeview HD tuner, and were very happy with what we saw. Colours looked wonderfully realistic with greens appearing especially lush; there’s no ghosting or triple-ball effect; and only very rarely we spotted the odd stutter which we couldn’t be sure wasn’t in the broadcast source itself.
Gaming
Samsung’s 2015 TVs have consistently delivered the lowest input lag among television models we’ve tested this year, but unfortunately the rabbit hole did not extend deep enough to the UE32J6300. Our Leo Bodnar device returned a figure of 42ms with the TV’s HDMI input labelled as [PC] which also permitted for full 4:4:4 chroma reproduction.
Conclusion
The Samsung UE32J6300 is without doubt the best 32-inch TV we’ve reviewed so far when it comes to picture quality. As more and more buyers opt for larger TVs, the 32″ segment has become somewhat neglected, with displays of this screen size invariably getting handicapped in the areas of calibration controls, colour accuracy, native 24p playback or motion resolution.
Samsung’s 32in J6300 proved to be a wonderful exception. It offered the full suite of 10-point white balance controls and advanced colour management system (CMS) as found on the company’s higher-end 4K Ultra HD models costing thousands of pounds more, contributing to outstandingly accurate image rendition once greyscale and colours were dialled in. Motion handling was another big step up over other 32-inch televisions we’ve seen: the 32J6300 presented 1080p/24 Blu-ray films smoothly without judder or interpolation, and even had room for an eminently usable black frame insertion (BFI) system to boost motion clarity.
If we had to nitpick, input lag could be lower, though please bear in mind that the numbers posted by the UE32J6300AK were perfectly acceptable for playing video games right before the 2013 and 2014 Sonys as well as 2015 Samsungs came along and blew everything else out of the water. Viewing angles were also not the best, but it’s par for the course for VA LCD panels, and we’d take this over the shallower blacks and reduced contrast that plague IPS screens any day.
And it’s not as if the price of the UE32J6300 is prohibitive; in fact, it’s downright affordable. The recommended retail price (RRP) is set at £500, but street price has already dropped to around £400 at this time of writing. If you’re in the market for a new 32″ TV, the Samsung UE-32J6300 should be your first choice, even if you’re not a fan of the curved screen format.
currently available for £349 with a 5 year guarantee at john lewis
