Caporegime
- 18 Oct 2002
Yeah, AMD took 980ti, clocked it at 1500Mhz and ran Hitman at 1440p@60fps minimum and called it a day![]()
Fury X sure ain't gonna do it with a 20Mhz increase
Fury X sure ain't gonna do it with a 20Mhz increase![]()
Next Total War is meant to be DX12 according to the dev,so looks like another AMD sponsored game.
Interesting enough i though. It does seem the rumours that Nvidia will partner with Samsung for HBM2 and AMD will stick with Hynix could be true, thus NVidia could have a decent head start getting HBM2 supply. However, i think Nvidia will be using HBM2 for their Tesla parts first so consumers might not get access much earlier than big Polaris.
I can certainly imagine that nVidia would have such need for HBM2 that Hynix had no chance of satiating their demand! Hence them hunting out the Samsung partnership...
I just don't see the logic in them doing HBM1 and GDDR5, when HBM1 is limited to only 4GB, as everyones just going to buy the GDDR5 cards, as no doubt they'll be 8GB like the 390s.
Why? If polaris 10 kicks some serious arse, it doesn't matter how much vram it has, as long as it is still kicking arse. AMD proved they can optimize memory usage.
It does though doesn't it, as look at the 390s, they are slower than the Furys, but they get recommended over them now for games, due to having more, and also, games coming now where you have to turn settings down on the Furys, which you don't have to do on the 390s, because they have more.
They get recommended due to them being great performers for their price. Simple as that. Not everyone can afford fury/x.
I just don't see the logic in them doing HBM1 and GDDR5 together again, not when HBM1 is limited to 4GB, as everyones just going to buy the GDDR5 cards, as no doubt they'll be 8GB like the 390s.
Its games specs where they are getting recommended over the Furys, look at GOW ultimate, the makers are saying you need a 390 or a 980 Ti ideally, as they both have more vram.
But are they limited to 4GB with HMB1?
Yes.
I remember Joe Macri said the following
“You’re not limited in this world [die stacking world] to any number of stacks, but from a capacity point of view, this generation-one HBM, each DRAM is a two-gigabit DRAM, so yeah, if you have four stacks you’re limited to four gigabytes. You could build things with more stacks, you could build things with less stacks. Capacity of the frame buffer is just one of our concerns. There are many things you can do to utilise that capacity better. So if you have four stacks you’re limited to four [gigabytes], but we don’t really view that as a performance limitation from an AMD perspective.”
who's to say they don't manage to use more stacks of HBM? And afaik they are using HBM2 on their top end cards.
And AMD also said that the Fury X would be an "overclocker's dream"... I don't put any stock in anything AMD or Nvidia say, or even the press... I will believe it when I see it. It's all marketing hype and nonsense, and invariably believing a shred of it only leads to disappointment.
Yea I know they said that and it was total garbage but honestly do you beleive they can't use more stacks of HBM? For all we know they have created more room on the interposer to allow for more stacks of HBM (because of a smaller die?). Anyones guess atm. Don't think a previous cards limitation will mean future cards will suffer from the same limitation. Kinda naive.
