- 9 Jun 2015
Hi guys,
Just built a new system, works well under load but there are a few glitches.
Half of the time, when I start the system, there is no signal to the monitor.
a) The fans are running in the system, I can hear the system starting but there's nothing going out of the gpu.
b) I thought maybe the video was coming out of the motherboard integrated graphic chipset so I plugged the hdmi into the motherboard instead: nothing happened.
c) when I turn off the pc and switch off the psu and reboot: it works
d) could it be that the gpu is poorly powered? I've used the y cable, but apparently the evga G2 650w in single rail, so it's supposed to make no difference. I'll still try that at some point.
e) the gpu is from my previous build and I've had it for 15 months, it's always been fine.
f) the motherboard is a Asus z170 pro gamer, with lots of LEDs flashing around when turned off - could it draw power and mess the system at boot?
Here's my system: i7 6700k, evga G2 650w modular, MSI 970 gtx, Asus z170 pro gamer
Thanks for reading
Thanks for reading
