Picasa still. It's just so simple and easy
I've got all my digital photos from 1997 to now in year, then yyyy-mm-dd occasion. Basically, what windows does when you insert a memory card, but broken down by year.
Yes, I got my first digital camera in 1997. It was an Olympus that took 0.3 megapixel photos (640x480). It was actually a decent camera. The pictures were bright and clear when monitors were also 640x480. However looking at the photos now the resolution was just too low.Do you mean photos digitised via a scanner from 1997, or did you actually have a digicam back then? What sort of picture resolution did digicams take back then? Must had cost you a fortune too!!
I think my parents had their first digicam in 2000 and it took 1024x768. Wasn't cheep back then either.
I had my first digicam in 2004 and it took 4MP. Camera was about £175 (Olympus C765UZ).
I replaced it in 1999 for one that took 1 megapixel photos. That one was a crap camera, but the better resolution made up for it.
I haven't uploaded anything before 2003 to Google photos as the cameras before then didn't a save exif data properly.
Update for Vimes - I've just ran FastStone Photo Resizer, and it's EXACTLY what I was after, so many thanks! Batch resize, but allowing to maintain the original file dates. Extra points that the site offered a portable zip as well, which I swear by![]()
Does LightRoom allow you to tag photos etc. so you can search easily down the line?
I currently just have folders, which I name with the date and event, but it's getting a bit messy
Yep, you can add as many keywords as you want.
but what's the correct way to import to an existing photos folder?
