1300Watt PSU is not enough for a 5930k + 4x 980 Ti.
i should think it is, why what would be suffice? 1600 watt?
Totally agree with this. Sli is more trouble and expense than its actually worth.
yeah you right, thats why ive decided to quit on 4 way sli, gonna flog all my extras on the bay or MM, i might keep the broken one or flog it for 250/275, im sure some one can fix the fan....
whats that you got? 2 psu's? ive got a 1300 watt which i think has plenty of power
a solution could be to put a aftermarket cooler on the broken card, and install that card on the bottom slot assuming there is room?
I'm not sure I've heard of anyone running quad SLI on air, its sounds like a bad idea to me. If you have money to throw away, then investing in a custom water build would probably represent slightly better value for money than that 4th 980ti your bought did? That would be my recommendation considering how all in you are anyway.
if i had the expertise then I would waterblock it, unfortunately I dont, even if i tried id probably break it more.
