I'd like a golf gti dsg, but I'm concerned about the gear box longevity.
I'm going to spend 9-10k, and this will buy 2007/2008 gti.
Any one own a car with dsg?
I read extended warranty would be a waste of money.
Which year ? Mk5, mk6 ?
Mate of mine had the extended warranty on an Ibiza Cupra of his with the 7spd DSG and from the bills he showed me, it very much wasn't a waste of time and worth the money.
That was with SEAT though, not sure if you can get a VW extended warranty that works the same but I assume so. It paid for itself many times over.
The Wet 6 speed and Dry 7 speed (which i guess he has?) are two totally different boxes, the dry is not related to the OP.
I have the Wet 6 speed in an R36, this car will put the box under more stress than most stuff VW offer, to date the box has been perfect for the last 93k.
Most of the time it will be the mechatronic unit which fails, and will be around 1.5k to sort out, so hardly any different from a manual clutch and dual mass change.
Any reason you want the DSG? Since these cars are getting on now I'd opt for a manual for longevity.
Because the DSG is a nicer drive and has an auto option?
These are fine as long as they're looked after, I didn't have problems with any of mine (I've owned a mk5&6 dsg and now an stronic a3: you might want to consider these also)I'd like a golf gti dsg, but I'm concerned about the gear box longevity.
These new sealed auto gearboxes are nothing but trouble. Of course they're going to heat up and the oil is going to burn? Why not make them serviceable? I'm sure people would prefer to spend more to replace the oil every year than wear the box out completely.
Ridiculous.
