- 7 Jun 2010
- Dublin, Ireland
Hey folks,
I'm just about to replace my Rampage V Extreme with a new one (issue with audio) and as such, I will be draining my loop.
I was going to use this time to make some changes to the loop, and wanted some input on using quick disconnects. I have been searching on some to get, but seems there are issues with them.
The Black Koolance ones I was looking at seem to consistently have issues with corrosion, and their response has been pretty dreadful. So not likely to buy Koolance anything since they don't care about their products.
Can anyone recommend some alternatives.
This is a log of my current build.
http://imgur.com/gallery/4mOi9
The idea now was to add quick disconnects to the top rad connecting to the GPU, and the the bottom rad connecting to the gpu. This would allow me to completely remove the GPU from the rig.
However, i figured, adding the QD's to the gpu itself in an opposite fashion. male on tube, female on gpu - male on GPU and female on tube. This would allow me to remove the gpu and connect the loop again, all without draining it. Handy for using a different GPU.
Basically, I'm just looking for some insight as to if this would work okay, and what QD's to get. Space may also be a concern as having QD's behind the gpu as it's currently mounted may not be enough room.
Hopefully, I was able to explain that properly.
