Does sound daft, but have you made sure Windows is set to 144Hz.
You say that you just swapped the cards over. Did you uninstall the drivers and replace them with Fury X drivers. Even if you did you could try removing the drivers and try another install.
I've sorted it
Cant believe what it was
The Division was set to run in full screen windowed mode and it will only let you select 60hz
Changed to fullscreen mode and 144hz was selectable again. doh![]()
if it's checked at 144hz, doesnt that mean it's 144hz ?Just checked was already set to 144
I've sorted it
Least you managed to sort it![]()
...and CPU that can hold minimum frame rate as high as that, especially for gaming onlineNow all we need is a card capable of running it at 144 fps![]()
