Man of Honour
There's been a few times I've ended up trying to force it in the wrong place (HDMI port) which lead to much disgust.
Careful. Make sure you take precaution and check your devices for viruses.
I've lost count of the amount of times I have plugged the USB into the network port, if you know what I mean.
A word of warning: don't try and insert your lead into a port that is in sleep mode, it will cause a hardware error and you might not have access to that port for weeks. Be prepared for the USB hub to remind you of this at every opportunity and could possibly result in you having to watch DVDs of other ports in action.
A bit tight?
I have a slight issue.
Went to use the main port last night, but it almost felt like the port had been used earlier in the day. I was at work and the unit should have been CCleaning, checking event logs shows that 3 different ports were utilised during the day by several unknown peripherals.
I am now trading the unit in for a firewire port.
USB ports are a pain. How many people have tried to plug a cable in, got it wrong, turned it round only to find it's still wrong and gone back to the original orientation only to find that it was right first time after all!
Just a word of warning - whilst this thread is good fun we are skirting a little close to the line so it may have a bit of limited time left, so get in quick.
