- 3 Oct 2009
- Wales
I'm going to take a punt, not least because I have a list longer than my arm of things I should really spend the extra £100 on
If it's **** I'll buy a Weber next year
What do people think to this? http://direct.asda.com/Classic-56cm-Kettle-Barbecue/001629727,default,pd.html?cgid=D26M09G09C02
Same size as a £134 Weber from B&Q.
I suppose the only thing really missing is a 10 year guarantee but that's hardly worth £100!
Would be used for normal bbqing and smoking.
A 10 year guarantee is absolutely worth £100. I used to end up buying a £40 BBQ every year thinking, "It's cheap I can afford to replace it". After buying a weber I see how much cheaper the total cost of ownership is as it's in it's 7th year and going strong.![]()
I can tell just by looking at the picture that it's cheap rubbish. The metal will be thin, the fixings on the legs look iffy at best, and after a few uses you'll probably find the lid will warp. Personally, I wouldn't waste £39 on something that will need to be replaced next year.
I'm going to go against the flow here and say that it's probably going to be fine to use. As others have said, you'll no doubt find that it rusts and warps a little and you may need to drill some holes to improve the airflow but as long as you see it as semi-disposable then it'll be fine. If you really get the bug based on your experiences with it you can always buy something better.
After reading this thread I have decided to buy a smoker, probably a proq frontier as they sell them locally. It would be good to have a hints, tips and recipe section! any recommendations of recipe, hints tips websites anyone?
Amazing Ribs is a classic website to start with. Although as someone with a ProQ Frontier, they are so easy to use I would read a lot but not get too fixed on detail just yet. I would certainly factor in the cost of a chimney starter and remote thermometer as the lid one is rubbish - I have an ET733 and think it's great.
Then it really is as simple as get a nice big piece of pork shoulder and rub with any recipe you can find online, light the fire at 0900, stick it on and wait. I have my vents at 1/3 open at the bottom (top always open) and it sits at 225-250f for hours. Take the meat out when it hits 203f and accept the adoration of family and friends!
Do you have to throw more wood/charcoal on through the smoking process? (I don't even know how much to put on to start!
All depends what method you use, I have a weber smokey mountain, can't for the life of me remember the name of method (But you fill your charcoal leave a hole in the middle and add a small batch of lit coals)
With regards to the wood, your meat will only absorb a "smokey flavour" for a limited time, after that adding more wood is pointless. Just have a check before hand for what you are cooking.
