*** The Car Cleaning Thread ***
Status
Not open for further replies.
Is there a decent product that helps with brake dust I can use on my alloys? Looking at getting my alloys recoated in the next couple of months and wondered what I could help use to prevent it and give them some protection?
I recently got Bilberry wheel cleaner, it hasn't impressed much so far, maybe I diluted it too much, I did 250ml of cleaner to 500ml water I think.
Dragons Breath is great but expensive.
I use bilberry neat. Along with wheel woolies and a coating of either HD wax or Autoglym wheel seal (the new stuff), the dirt just washes off with absolutely no hassle.
Bit of a bump, but I've decided that I don't like the hose that came with my Nilfisk. Length isn't bad (8m), but because it's quite stiff plastic, it keeps coiling itself back up and getting tangled and twisted as I'm walking around the car.
Do you find the directhoses replacements a bit more manageable? The one I bought for the Karcher was nice and heavy and easy to manage, but it came from "cleantec_online", who seem to charge a lot more. I don't want to buy a replacement longer hose but find it's still quite cheap and light and keeps trying to recoil itself.
I would like an answer on this too. The hose is a complete pain.
Use Iron-X/any fallout removing wheel cleaner and clay them every few months, then apply a good sealant to them. Something like FinishKare 1000p :)
Which nilfisk do you guys have? The hose on my £60 effort (c120?) is fine, could even be a case of getting one meant for a slightly different model - or maybe they changed them at some point
Pretty sure I've got the direct hose one. It's absolutely perfect and doesn't kink. The standard nilfisk hose was driving me insane.
For alloy protection I would give them a good clean or refurb and apply something like Carpro Dlux. It's easy to apply and provides protection for 1-2 years... Plus you can do all the black plastic trims with the leftovers
EDIT:
Still early days but one month after application of dlux, around 800 miles -
Cleaned with pressure washer & just a soft brush with shampoo -
Beading very nicely.
Re Alloy wheel cleaner....you can sometimes be paying out of your backside for something that is cheap but rebadged. Mercedes Benz star gard alloy wheel cleaner...and another make.....nothing more than oven cleaner with distilled water added....alloy wheel protector..again....stainless steel cleaner. Small can Halfords de-icer...works down to -20 compared to a large can of Unipart de-icer..works down to -15.....yet they are the same product...both coming from a large tote labelled Halfords de-icer. Just some interesting facts to throw your way.
Probably an obvious question but those who polish with DA on their car, what do you do on awkward places such as around the number plates and around the door sills, do you just use hand polish around those areas?
Thanks guys. So Bilberry/Dragons Breath and some Iron-X followed by wax/sealant?
I do like Collinite 476S. I last applied it to the Scoob about 10 months ago and it's still beading. Surely a wax of this quality will go some way to protecting the wheels? I have loads of it left.
I can only dream of the time when I had weekends to machine polish a car. The Scoob is in dire need and between work, study and family with a 6 month old baby I have NO time for cleaning cars :D Hence the need for something strong to get the wheels looking their best.
A bit of nostalgia, here's the Rover in all her machine polished glory...
These pictures were several years post polish. Just goes to show though, if you look after paintwork it'll stay in great condition for many years.
P.S. Sorry for the black wheels Howard
The top picture is OZ Ultraleggera wheels with Eagle F1 GSD3s, so it's not all bad ;)
Used Chemical Guys Hybrid V7 car shampoo, finished off with Hybrid V7 spray detailer/sealant and Megs endurance tyre gel. :cool:
If you're looking for a streak free quick detailer I cannot recommend CG enough. One of my new favourite products.
Without having to delve in to the whole of this thread, what clay bar do people recommend? Clay mitts okay?
I'd be very carful with a rotary as good as they are as you can burn through the paint very quickly. However, it will give very good results.
I'd personally be looking at a Rupes Mini DA.
Status
