- 18 May 2010
Hi,
I know this is difficult to answer without reviews/benchmarks etc but I'll ask for your views anyway -
In regards to what are now considered older CPU's like my 8350, how will these handle the upcoming GPU's? Will there be a need to upgrade the CPU or is it a case of the new GPU's will be more than happy running with older CPU's? What kind of performance difference will we be looking at if a new GPU is working with an older or newer CPU, is it negligible?
I'm trying to figure out my upgrade path, this year I want to upgrade my -
1080P 120hz monitor
290X
And CPU if definitely required
Problem is, I probably wont be able to afford to do it all this year hence the question
Thanks
1080P 120hz monitor
290X
Thanks
