Budget Tablet - Nexus 7 Still worth it?
28 Dec 2002
My son Hudl has just died and looking for a budget tablet replacement, want to spend around £100 mark. Currently thinking about the Nexus 7 but worried it now 3 years old has anyone got any other recommendations?
I am using mine to write this. Still super fast and on Android 6 getting the monthly security updates too.
I haven't looked at getting a replacement and don't plan to for a while
Just bought a nexus 7 on the mm here. It's a long way better than the hudl 1 we also have. It was £100 at argos, when I last checked.
Lacks a sd card slot and hdmi out, which hudl has, if those are important to you
Yes, bought my daughter one last week from a high street retailers Ebay store refurbished for £79.99 and its bloody superb for the cash.
Can't see anything better for the money.
We recently got my daughter a Kindle Fire tablet. It's great for the money I think. Does all the stuff that she needs. Can't really argue for £50. They do a 'Kids' version for £99 which they'll replace for free within the first 2 years if it's broken by your kids.
You can pick up the 8" Lenovo Yoga 2 for £99.
I bought the 10" version a fair while back and IMO it is night and day better than the Nexus 7. Personally I'd be looking and seeing if I could find any deals on the newer Yoga 3's, but that's just because I rate the one I've already got.
I liked the Nexus 7 in it's day, but no way I'd go back now.
I have one of the original 2012 Nexus 7" tablets and I'm finding it so slow that it's pretty much unusable since I updated it to Lollipop. Like the OP I'd quite like to buy a cheapish tablet to replace it. Personally I find the 7" form factor is a bit small and so close to the size of my phone that it doesn't seem worthwhile anymore so personally I'd suggest something in the 8-10" range for a tablet these days.
I did consider the Nexus 9 but at £250 it's around £100 more than I really wanted to spend on a tablet. Lenovo Yoga looks good but the res seems quite low for a 10" tablet at 720p.
Anything else worth considering?
The 2013 Nexus 7 is virtually the same spec as the Lenovo, is running Marshmallow perfectly and has received security patches every month this year, there is nothing wrong with the Lenovo but specced and priced the same I'd take a Google device all day long.
What would be your first choice?
I'm not a Nexus fan due to the lack of memory expansion & I was looking around and can't find any great deals on at the moment, there were quite a few before Christmas though. Anyway I'd have recommended a Hudl 2, just got my mother's barely used one but they're no longer available :(
If you don't have to have Android there were quite a few Windows tablets for around that price point, I almost bought a Lenovo Miix last December at £100.
I'm also wondering about the cheap chinese tablets, the phones are highly recommended but have the tablets caught up yet?
Still use my Nexus 7 2013 till this day. Nothing has come to beating it in the 7 inch market. All other tablets are too big, no support or cheap Chinese tablets with stuck on Android 4.4.
Yeah I would have had an older version to be fair and hadn't looked to see the spec for any newer versions. I'd still recommend the Yoga to anyone, but if the 2013 Nexus 7 is comparable in spec, then I guess it can't be a bad option either.
Does the 2013 Nexus 7 match the Yoga on battery life? What about support for using micro SD cards?
They were two of the big things which I found the Yoga had over my old Nexus.
