a hundred 100 hours and your at level 20? what have you been doing?![]()
I had delta issues and with virgin media.
after I posted here I got on with the next try and was on for hours without a issue
I've had a few issues with Delta, but usually a couple of retries gets me in.
Had a weird issue with a couple of the challenges yesterday. When I have held Tab to go to the group, I have ended up at an entrance point to DZ6(twice) and a safehouse. I have no idea what was going on.
My friend was deconstructing gear in the DZ so he could pick up some purples and magically got the loading screen and he was in a safehouse O.o
I treated it too much as an open world exploration game early on. Spent way too many hours just exploring and not doing the high XP missions, side missions etc. I would also do 1 side mission in a session and then go off exploring or spend too much time in the BoO going through the latest jackets or pants that I had acquired to see what matched the best.
Trick I found with the delta issue - start a new character then log out & try to log your main, this worked for me, ymmv.
I tried to do my first challenging mission yesterday, people were dying quite often, I was lagging out for minutes at a time then I eventually got stuck at a restock box and couldn't move. So I got kicked
Continuing on from what Dr Fate said about the story getting lost in the XP rush, I feel like reaching top level was too fast, after reaching 30 there are still a heap of missions I hadn't done and some areas of the map that i had not even explored. Bit of a waste when you're going back to get wing points and all the drops are level 25 and none of the enemies are at all challenging.
Should be on tonight if someone wants to run me and likely stark through some missions.
It's too easy to reach lvl30, there's just too much XP to be had. I got to 30 and had only done 75% of the main missions.
I played with half a dozen different groups on the challenges yesterday, lost count of how many times I died.
Even went into the DZ in the early hours, every entrance I went to, to enter, there were 2 or 3 Rogues loitering about. I'm not geared up enough to take them on, so got out and just farmed crafting gear and done a couple more challenges.
I've stopped heading the to DZ in the evening due to the amount of rogues, you can't get anything out.
I've found between 1-4am the best time to head in.
Not ventured into the deadzone yet for fear of losing rank and basically being overwhelmed. Maybe if a mate went with me but i dunno. Is it worth going in at a lowish rank?
