NASA 'cuts space station video' immediately after bizarre UFO hovers above Earth!
Yeah it's defintely chromatic abberation or similar. Being that it starts out as a curve then moves into a circular shape then and fades out to another curve, you'd have to make the most obvious assumption that it's flare following the shape of the lens, or lens hood.
My suspicion is that there is a slow moving light source somewhere underneath or above the lens, not in the distance as the perspective is making you think.
Just because I can see it's not lens flare doesn't mean I also think it must be Martians.
You can't see it's not Lens Flare, you think it's not. That's a very very big distinction.
Looks suspiciously like a halo that you'd get when something like the moon or the sun is rising, and the "object" is the part not obscured by refraction in the atmosphere.
Livestream cutting out could be anything, because y'know getting a stable internet connection to a tin can flying at 17000 odd mph with no links to the ground is really easy.
But y'know its plainly aliens
didnt the conspiracy theorists tell us the space station wasnt real a couple of weeks ago??
Well it must it a million years later because that is lens flare.
(is my sarcasm detector broken?)
Whatever kind of visual aberration it is, it doesn't look like lens flare. Also to my eye it clearly and consistently recedes into the distance as opposed to distorting and disappearing as when lens flare happens. In addition to this the camera doesn't appear to move position and neither does the sun, so what would cause lens flare to appear then disappear in such short space of time?
Pretty obvious that Nasa would add stream delay to this kind of thing so any 'accidental reveal' is a hoax or nonsense.
The light source from elsewhere on the station, most probably.
Conspiracy Theorists disagree on everything eg
Man can't get off the planet
Even if man can then he can't get through Eddie Van Halen's belt
Man didn't land on the Moon
Man did land on the Moon but there were Aliens there
and so on ....
