8 Apr 2016 at 20:16 #41 Bone9 Bone9 Associate Joined 17 Jul 2015 Posts 1,206 Gibbo said: Yep if comes back Ford can glue it all up. Click to expand... You should try to avoid glueing as it makes it near impossible to get the shaft out. Most ST boys end up having to replace the hub too.
8 Apr 2016 at 20:18 #42 Gibbo Gibbo OcUK Staff OP Joined 17 Oct 2002 Posts 39,513 Location OcUK HQ Bone9 said: You should try to avoid glueing as it makes it near impossible to get the shaft out. Most ST boys end up having to replace the hub too. Click to expand... Well if it comes back, Ford can fix it via whatever method they do.
