fao: amdmatt
3 Jun 2012
Yo.
you posted online on the 10th of March that AMD will be working with the Dev of the division to fix the poor crossfire support. When I say poor I mean non existing support. I cant play it at all.
AMD really needs to talk to devs to make sure mgpu works before they get ripped to shreds after a game release. It hurts AMDS rep.
any reply would be nice as it's been a month since you told people they will be working with the Dev to fix it
speak to them on twitter. they often reply instantly.
its not just amd nvidia do the same. bugs happen.
Happened on SLI also guess its also AMDs fault :p
edit
Anyone tried Dying Light running more updated version + Drivers?
Patch 1.5.2 release notes
(Windows only)
- Fixed performance issues for Crossfire hardware setups
What's the point in dedicating time to fixing FOTM games like Dying Light... people blow through them in a week then they are completely forgotten.
Been playing dying light for past couple months. They is more to games than just story. I haven't even touched the DLC yet.
The new big DLC is pretty good although a bit to short but otherwise good. Had a **** ton of fun going through it with a friend. Only mistake is the last boss fight cannot be done in Coop.. major let down :(
Really???? Daaaaaaaaaaaaaamn that is NOT good!!!
Get yourself a good overclockable Ti and dump 'em tbh, you'll never look back
Until Nvidia start the gimping :D:D or killing cards.
Even then I don't know why he can't use single card without problems. I use a 290 and 3 other mates including one with 290x 8gb crossfire play on single gpu without issue. In crossfire my mate has all the horrible flickering but disabling solves all those issues.
Single card should be fine. Crossfire support really needs to improve but so does sli/dx12 on Nvidia. Pc as a whole seems to be facing more issues.
Swapping vendors might fix an issue but you will probably just be landed with others. On the other hand with a good budget the 980ti is the best option for single card users. Titan X does not offer up more performance once clocking so wouldn't recommend it.
I play on a 4k monitor. Need the powaaahhh
