- 19 Dec 2010
- Berkshire
total noob here, how do you use the cinema app on the home screen to watch films?
Why would you want to? It's not using the full resolution of the panel, so it will look like 480p (or worse).
Isn't there a cinema app?
I just use VLC running inside Virtual Desktop. No messing about then.
It's much easier to use either virtual desktop or VorpX to watch movies as you can use VLC or MPC-HC which can actually play everything rather than the very limited number of content types the Oculus player supports
What is VorpX like? It looks expensive.
