OcUK Staff
 - 26 Nov 2014
 - Stoke
Ever been stuck in a situation where you're planning to upgrade but your current PSU doesn't quite cut it? At near full load and your current PSU is taking a performance & efficiency hit? Seen a good deal on a second PSU but it's not as powerful as your current system unit? Want to run a redundant PSU setup on your system but put off by the high cost and form factor of current redundant power supplies? Want to make a 2000W+ monster gaming rig? Want to take over the world and need a pair of 8Pack 2000W PSU's in the same system to do it? Phanteks has you covered.
The Phanteks Power Combo is able to combine a pair of power supplies to provide a single combined output within your PC system. The 20+4 Pin and 4+4/8Pin power connectors are combined to a single output which not only improves efficiency but supplies a redundant function to avoid data or hardware loss due to a PSU failure. This also means you can operate any combination of power supply wattages and certifications to provide a single stable output to your motherboard, more efficiently than either PSU would normally run independently. Pretty neat to be honest.
PCI-E/SATA devices are connected independently to the power supplies, but this gives you a wealth of SLI & Crossfire options. Any case with dual PSU support is combo ready, such as the Enthoo Primo series, Lian-Li D666WRX or the Corsair 900D. The stock is due to land at the start of May. Heres a nice video to show you more!
Phanteks Power Combo Device - 2 PSU to 1 Motherboard PH-PWCOB_2P1M @ £29.99 inc VAT
nonl2br
Phanteks’ patented Power Combo is design to maximize your power output by allowing you to connect two power supplies. Higher end power supply can cost a fortune, but the Power Combo is cost efficient and provides maximum power and efficiency. With the ability to combine two power supplies, the Power Combo can give you a higher maximum power output than all the power supplies in the market while still maintaining stability and performance. A true plug and play, the Power Combo requires no cutting and splicing of the wires.
Features
- SAFE AND SECURE: Redundant power supply architecture concept, this prevents the system from shutting down when one power supply fails. This ensures that all your vital information and data will not be interrupted or lost.
- EXTREME PERFORMANCE: Combining 2x top tier PSU’s and drive high-end systems that requires more power output.
- Universal Mount + Drop-N-Lock: The Power Combo comes with a velcro sticker that allows intallation in universal case products. The Power Combo is also equiped with a Drop-N-Lock mounting system, which makes installation even more convenient for Phanteks’ compatible *cases.
- POWER EFFICIENT: The power combo can acquire higher power efficiency through load sharing of 2 PSU’s. 2 PSU’s will operate under more efficient load compared to a single PSU that would be under full load.
- COST EFFICIENT: Budget builders can combine two low-wattage units to obtain a high end PSU performance without the high end cost.
- Cable compatibility: 24-Pin / 8-Pin Extension cables are required for connecting the power combo to motherboards. The power combo is compatible with all standard extension cables on the market. However, we recommend to use Phanteks’ *extension cables which are designed with extended length (500mm) for better cable management.
Specification
- Product: Power Combo (PH-PWCOB_2P1M)
- Dimension: 165 mm x 32 mm x 100 mm (W x H x D)
- Type: Power Combo for M/B 24-pin and CPU 8-pins
- Material(s): ABS
- Colour: Black
- Motherboard support: E-ATX, ATX, Micro ATX, Mini ITX
- Input Connector: 24-pin (2x) / 8-pin (4x)
- Output Connector: 24-pin (1x) / 8-pin (2x)
- Total Max Capacity: 1170W (Max. Motherboard consumption only)
- Power Supply Suggestion: Using Full spec PSUs ensure the stable power supplying output
- Cable compatibility: 24-pin/20+4 pin; 8-pin/4+4 pin; (extension cables not included)
- MTBF: >50,000 hrs
- Net Weight: 210 g ( 0.5 lbs)
- Gross Weight: 260 g ( 0.6 lbs)
- Package Dimension: 200 mm x 66 mm x 136 mm (WxHxD)
- QTY: 20 pcs / carton
- Model No: PH-PWCOB_2P1M
- UPC Code: 886523300625
- Warranty: 2 years
Only £29.99 inc VAT.
ORDER NOW
nonl2br
Features
Specification
- Material(s): ABS
- Colour: Black
- MTBF: >50,000 hrs
- Warranty: 2 years
ORDER NOW
