32 TV for bedroom
11 Jun 2006
I need a 32 inch TV for the bedroom.
It will be wall mounted.
It will probably be used for freeview.
Plan to connect it up with kodi and hopefully stream movies or TV over the network it possible or use plex?
What do I need to know?
You don't need to know much really lol a lot of the Smart tv's have the plex app. I think Samsung offer the best plex app in there Smart hub. And you can Stream movies over the network if the tv is DNLA which most are these Days. There is no KODI app in the Smart features so you will need a device connected to the TV for that. However Sony do Android tv's which you can load kodi onto
Thanks, does panel quality matter and is there much difference between 720 and 1080 at that size?
It's a shame as those new LG models look really good.
As it's wallmounted anything on particular I want?
Hi again ;)
Is this an updated version of what you said?
http://www.richersounds.com/product/tv---all/samsung/ue32h6400/sams-ue32h6400
Other TV's I have been looking at are:
http://www.richersounds.com/product/tv---all/lg/32lf580v/lg-32lf580v
http://www.richersounds.com/product/tv---all/samsung/ue32j5500/sams-ue32j5500
http://www.richersounds.com/product/tv---all/sony/bravia-kdl32w705c/sony-kdl32w705cbu
http://www.johnlewis.com/lg-32lf650...view-hd-built-in-wi-fi-2x-3d-glasses/p1973301
Will need to be wall mounted in bedroom, plan to use normal freeview / plex / chromecast and amazon firetv stick so whatever is the best.
If possible stream TV shows over network to this TV will be its primary use after freeview tv.
I just want it to look good at an angle as it will be above the bed and the wall is fairly thin so lighter the better and same if it can be thin.
I got the Samsung 32 5500, it was the lightest and being mounted on a thin wall made a difference. It also had the best reviews and was the most popular. It was either that the Sony or the lg
Yeah like I said I got the 5600, seems there's virtually no difference between them at all but the 5600 was available locally so I got it.
Very nice little set, I'm very impressed with it. The Wifi reception on it is utterly diabolical though, if that matters to people.
