Anyone used Gigabyte's OC Guru II Software? *problems*
11 Mar 2016
I got my nice new GTX 970 windforce 3 and Ive downloaded many times and re-installed many times, but cant get the OC Guru II software to open - it just flashes up the dashboard controls for a millisecond then dissapears - unable to see. It shows in the active running applications but is impossible to see.
Is this a known problem for this GPU or is it maybe a problem with something ludicrous like not working on 64bit platforms?
(Did a search and found no threads on this software)
For GPU clocking - I too had issues with OC Guru.
I use MSI Afterburner on my Galax card (It works on ANY brand) and everything works and clocks like it should!
It is a right click and open application from the tray. Or does that do the same thing?
It does the same thing. Interestingly, the separate Gigabyte App Center loads fine from the tray, as well as its easytune mobo software. Just OC Guru II doesnt show up anywhere.
I may have to go with MSI afterburner or the Guru 3D one of which the name I forget.
Afterburner or evga's precision x are very similair. I prefer msi afterburner myself though.
