I'm a bit of a "Frames Per Second" fan, worried I may lose frames if I purchase a high resolution monitor. Sorry for my lack of experience, it's been many years since I built a gaming rig.
Thank you for the advice.
Im using a very old 19" Viewsonic. The rig is a gaming setup. Ive been meaning to get a new monitor for a few months.
After some research I couldn't make up my mind.
Right, the budget is out the window after seeing the Acer Predators. It's beens on toast for a few months. Two possible options, the 1080p or the 1440. Would I be correct if I said the 1080p will give me more "Frames Per Second" with a single 980ti. There is lots of hype about the 1440 but is that at a cost of FPS. ?
Thanks again for the advice.
After that I was hooked. Quake series, CS, CoD, MoH.
