Looking at replacing the fans for something a bit quieter. 120mm I think.
Any suggestions.
Andi.
Cheers Kelt.
Bought the AF120's as they are slightly quieter.
Andi.
Daresay they'll be OK, but they're case fans. Personally I would have gone for the SP (radiator) fans.
What would be the difference?
Andi.
Better efficiency with the SP fans, translating to better cooling.
I cant give you the technical why's and how's butHow do they measure that?
Andi.
AF create better air flow
SP have a higher Static Pressure which is apparently good for pushing the air through all those fins on the radiator.
thats the gist of it
