- 27 Jan 2009
- United Kingdom
As the title says really my space is very small.
I'm looking at the cheapest one the C80 (Don't have enough to buy the expensive ones but I need to make sure I can actually sit on it!) mind you the amount of use it will get I can stretch my budget!
The space I need to fit this in is as follows.
The clearance between the edge of my desk and my bed is 40cm the depth of my desk is around 50-60cm so the, chairs should tuck in nicely.
The height of my desk is just under 70cm, but I would like it so even if the arms are under the desk I can still rest my arms on them.
Basically I need a chair that i have enough space to actually sit on, for example can I sit in it if the chair is in that small area, if I rotate it 90 degrees is there enough space for me to climb into it.
Not sure how much people here could help me with this, the amount of space most people have is a like a open savanna compared to what I have to squeeze into.
EDIT: I need to get this delivered ASAP, the most realistic day is Saturday does the free delivery apply to Saturdays or only weekdays? or can I pick the time it will be delivered as the sooner the better but I wont get home from work till at least 6:30.
Thanks
Thanks
