** NEW TEAMGROUP DELTA SERIES: BREATHING MEMORY!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
We now have the latest TeamGroup Delta series RAM in stock which breathes, OK not quite breathing but has pulses red LEDs and is built by Avexir for TeamGroup, so no patent infringement. Now in stock! :)
Team Group Delta 8GB (2x4GB) DDR4 PC4-19200C15 2400MHz Dual Channel Kit - Red Light (TDTRD48G2400HC15ADC01) @ £38.99 inc VAT
Team Group’s all new overclocking memory series – Delta is a high performance memory module created specifically for the 6th generation Intel Core processors and Z170 motherboards. Developed and certified according to XMP 2.0 standard, Delta provides absolute performance, stability and reliability with laboratory-scale burn-in test and compatibility verification for major motherboard brands worldwide.
Team Delta series combines LED and high efficiency forged cooling module. Frequency of all products of the series starts from 2400/3000MHz dual channel module, which offers overclocking enthusiasts and gamers a fast and smooth DDR4 experience on the Skylake Z170 platform. Let a breathing overclocking memory helps you winning at any gaming battle worldwide.
Specification:-
- CPU Compatibility: Intel Skylake
- Chipset: Intel Z170
- Capacity: 8GB (4GBx2)
- Dual Channel kit: Yes
- Tested Speed: DDR4-2400 MHz (PC4-19200)
- Tested Latency: 15-15-15-35
- Tested Voltage: 1.25-1.35V
- 8 layers PCB
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 288-pin UDIMM
- SPD Speed: 2133 MHz
- SPD Voltage: 1.2V
- Warranty: Lifetime
Only £38.99 inc VAT.
ORDER NOW
Team Group Delta 16GB (2x8GB) DDR4 PC4-19200C15 2400MHz Dual Channel Kit - Red Light (TDTRD416G2400HC15ADC01) @ £79.99 inc VAT
Specification:-
- Capacity: 16GB (8GBx2)
- 8 layers PCB
- SPD Voltage: 1.2V
Only £79.99 inc VAT.
ORDER NOW
Team Group Delta 8GB (2x4GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Red Light (TDTRD48G3000HC16ADC01) @ £49.99 inc VAT
Specification:-
- Tested Speed: DDR4-3000 MHz (PC4-24000)
- Tested Latency: 16-16-16-36
- 10 layers PCB
- SPD Voltage: 1.2V
Only £49.99 inc VAT.
ORDER NOW
Team Group Delta 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Red Light (TDTRD416G3000HC16ADC01) @ £89.99 inc VAT
Specification:-
- 10 layers PCB
- SPD Voltage: 1.2V
Only £89.99 inc VAT.
ORDER NOW
Fantastic prices on these! :)
Tempted by these. I take it that the part that lights up is along the top? Got a pic of these fitted and in action at all?
Edit: Just seen pics of the Avexir on the shop page - they look similar so get he idea - smart!
I currently have the Team Group Elite ram which has the XMP profiles loaded onto the ram - do these Deltas work the same way?
Do you have a view on the pros/cons of having the XMP profiles loaded on the RAM versus being able to enable/disable the XMP profile in the bios? What is the manufacturers thinking behind supplying them this way? Would just like to understand...
Thanks
I like the Blitz series a lot from Avexir, especially when they make different versions for different motherboard (Mpower yellow, L337 yellow, MSI Gaming Red, OC Formula yellow, Ultra durable green,etc). Now they only have the original series :(
Agree. It's either OCUK or Avexir that are extremely slow bringing stock in. Very disappointing :(
