I just bought an Intel Wireless-AC 7260 WLAN card for my laptop. Initially the laptop wouldn't even boot with it in in the WLAN slot but once I moved it into the other half-height mini PCIe slot (labelled "1/2 Mini"), it started working. However, I can't get a connection speed of more than 173.3 Mb/s. Occasionally it drops to 152 Mb/s but otherwise it's pretty stable at that speed, even when next to the router.
Does anyone have any suggestions to try to improve the throughput? The router supports 1300 Mb/s and the WLAN card supports 867 Mb/s (I assume 40 MHz only). I've tried these things already:
Specs:
EDIT: Just checked my Galaxy S5 and that is also connecting at 173 Mb/s on the 5 GHz channel. So it looks to be a router issue rather than a problem with the new WLAN card. The fastest I've managed to get it so far is to force the channel to 36 and channel width to 40 MHz. I can get 300-400 Mb/s on both devices using this method.
- Force 5 GHz band to AC only
- Force channel width to 40 or 80 MHz
- Force highest available 5 GHz channel
- Check WMM is enabled
Specs:
- Router: TP-Link Archer VR900
- Laptop: Dell Latitude E6530
- WLAN card: Intel Wireless-AC 7260
