Man of Honour
- 29 Mar 2003
- Stoke on Trent
A passenger plane thought to have been struck as it approached Heathrow airport was probably not hit by a drone after all, the government says.
Transport Secretary Patrick McLoughlin told MPs it was now thought what happened "was not a drone incident"
. Strange.It might have been "floating debris". Strange.
Very curious to actually what the hell it was!
My money's on a wayward SPAR bag.
/in the same article I heard yesterday they said they had a near miss at over 12000 feet - is that possible with the sorts of drones available to joe public? (I'm sure the military ones are capable of this)
I've dealt with a lot of reports 10000ft and above. The vast majority are below 5000ft though.
Regarding the incident which sparked this thread, they have not concluded that it definitely wasn't a drone. There just isn't enough hard evidence to confirm it was.
So it's a non-story to help drive the hate of them yet again, fantastic.
If find it very hard to believe a multi rotor would even make it that high (10k ft) before the battery died unless it was purpose built to do it. I can't think of anything off the shelf that would. Your run of the mill Phantom would get you to about 2500ft. The old model, before the added geo-fencing to the software. Even then, you wouldn't be able to see it that high. Even 150ft up, it's hard to see something that small line of sight.
A plane (powered glider more likely) can, but your average joe wouldn't be able to do it. Again, it would need to be purpose built and flown in the correct manner to get it that high. You can't just point it vertical and start climbing, as again, you'd run out of power.
