28 Apr 2016 at 17:01 #1 Glanza Glanza Soldato Joined 13 Mar 2007 Posts 15,983 Location South Yorkshire Anyone had any experience, if yes what do you recommend?
28 Apr 2016 at 18:36 #2 blueboy2001 blueboy2001 Soldato Joined 18 Oct 2002 Posts 4,898 Which P to which V? VMWare Converter works fine. Veeam Endpoint has its uses for very large disks for Windows to VMWare.
28 Apr 2016 at 19:52 #3 nutcase nutcase Soldato Joined 18 Oct 2002 Posts 7,626 Location SX, unfortunately I used MVMC the other day for the first time to convert a 2012 R2 install to Hyper-V VM and it worked fine.
29 Apr 2016 at 06:22 #4 paradigm paradigm Caporegime Joined 26 Aug 2003 Posts 37,514 Location Leafy Cheshire If it's a quick and dirty Hyper-V conversion, just run Disk2VHD on the P.
29 Apr 2016 at 13:41 #5 Glanza Glanza Soldato OP Joined 13 Mar 2007 Posts 15,983 Location South Yorkshire paradigm said: If it's a quick and dirty Hyper-V conversion, just run Disk2VHD on the P. Click to expand... Worked a treat, cheers for the other options guys.
