I see. wouldn't 750 Ti get Ultra on 900p ? I can afford this one and it's new too.
No chance with the 750 ti. The 960 is at least 50% faster. In some cases it is twice as fast.
Get a used 7870 and overclock it through the drivers. Super easy, low power and is perfect for your resolution.
Tho, will I be able to use R9 370 2GB with my 450 PSU ? I think the PSU is limiting me in this build the most.
Also, the fact that I can barely find any topic about R9 370 or review on Youtube makes me a bit suspicious about this GPU.
I would wait as the new gpu's will use a lot less power and they should be here June/July.
I was thinking about it as well but by looking at the current price range, I don't think so it will go any cheaper.
That is hard to tell but if anything when new cards are out, this gen will go eol and cheaper, AMD are pushing for a cheap vr base line so you might get a knock on effect of card lower than the vr baseline been more powerful than this gen at the same price, we can only hope.
Edit: From what I have read, it's the best way to go for Nvidia GPU if I want to get a better performance in games.
Who told you that? I have a GTX960 which is Nvidia's fastest sub £200 graphics card and no amount of marketing makes it faster on average than the R9 380 and R9 380X.
Which games in particular are you hoping to play at high settings? I mean there will be some games no matter what requires a decent gfx card and cpu at high or ultra settings like gta v. So just so your aware that getting a 960 or somit might help u play some games at high or ultra settings there will be some you cant. Just incase u were pinning ur hopes up on the gfx card upgrade thats all.
but like I said, I will need the new GPU for around ~1 - 1.5 year since after that I will be getting myself a completely new build. Fxaa should be doable as little performance difference, some complain of bluryness but i dont see it tbh.
Skyrim will run well on pretty much anything especially a nvidia gpu iirc if you mod the game tho performance will suffer and if too many mods then u might run out of vram iirc.
Gta 5 should run on a 960 i believe but make sure settings are mostly down, still should look quite nice tho but yeah keep settings down.
Other games not sure as dont think ive played em.
So if u said u have around £117 now, if u sold the r7 240 for 25-30 quid on ebay that brings you to around £142 ish. See if anything else u can sell that u never use anymore in the house to fund for a better gfx card, that or save up and try to aim for at least a 960. As seen some on ocuk for £158-165 range, go for evga if u can due to good support if anything goes wrong. Other sites might have cheaper ones who knows up to u in the end. But saving up a touch and selling ur old gfx card i reckon u can get a 960 easily enough within a month or less.
I meant it in general.
