So watercooling is something I've wanted to do for a while now, and I've been steadily doing some research over the last week to get my head around what parts I'll need and how to do it. I'll be watercooling the system in my signature
Rough loop plan:
Loop going Res>Pump>GPU>CPU>360>240>Res (there will also be a drain port/valve)
Looking at using the following parts:
Blocks:
Total: £194.03
(includes shipping: £11.10)
Fans|Radiators|Reservoir:
Total: £239.27
(includes shipping: £10.50)
Tubing|Fluids|Fittings:
Total: £137.37
Red/Blue dye is for making a nice purple (hopefully). I'll likely be doing a build log and adding/modifying parts for aesthetics later on (LEDs, PSU shroud, spray/wrap backplate and motherboard heatsinks etc.)
So now I guess a few questions:
Will it work?
Am I needlessly overspending anywhere? (It's already going to take a little while to save up for the parts needed, I'll be getting them gradually when I have funds.)
Is the Mayhems Blitz Pro necessary?
Rough loop plan:
Blocks:
- 1 x EK Water Blocks EK-FC Titan X Backplate - Black= £22.99
- 1 x EK Water Blocks EK-Supremacy EVO - Full Nickel= £69.95
- 1 x EK Water Blocks EK-FC Titan X - Acetal+Nickel= £89.99
Total: £194.03
- 1 x EK Water Blocks EK-XRES 140 Revo D5 PWM (incl. pump)= £99.95
- 1 x EK Water Blocks EK-UNI Pump Bracket (120mm FAN) Vertical= £7.99
- 3 x Noctua NF-F12 IndustrialPPC 2000RPM IP67 PWM 120mm High Performance Fan= £24.95
- 2 x Noctua NF-A14 IndustrialPPC 2000RPM PWM 140mm High Performance Fan= £22.99
- 1 x HardwareLabs Black Ice Nemesis GTX 280
- 1 x HardwareLabs Black Ice Nemesis GTX 360
Total: £239.27
- 11 x EK Water Blocks EK-ACF Fitting 10/16mm - Black= £4.79
- 1 x EK Water Blocks EK-AF Ball Valve (10mm) G14 - Black= £12.95
- 1 x EK Water Blocks EK-AF T-Splitter 3F G14 - Nickel= £6.29
- 1 x Mayhems Blitz Pro Cleaning System= £24.95
- 1 x Mayhems Dye Blue 15ml= £5.48
- 1 x Mayhems Dye Deep Red 15ml= £5.48
- 1 x Mayhems Pastel - Ice White Coolant 1L= £14.99
- 2 x Mayhems Ultra Clear Watercooling Tubing (38 - 58) 10/16mm= £1.69
- 1 x XSPC Hose Cutter (0-25mm)= £6.95
- 1 x EK Water Blocks EK-AF FillPort G1/4 - Black= £5.59
Total: £137.37
Will it work?
£31
(incl. VAT)
£29
(incl. VAT)
£10
(incl. VAT)
