Hi,
I am thinking about getting plantation shutters fitted over the bay window in the living room. Three reasons:
1) They look ace
2) They allow me to close the bottom half, (I would buy ones that are horizontally split into 2), stopping my living room being on full display to those walking down the street
3) They are supposedly great at blocking out road noise when closed (if well fitted)
Now has anyone had them fitted? What do you think? The primary concern for me is having them act as a noise barrier.. The road noise isn't bad, but I would like it to be less in the evenings Are they good at this? and is it more high frequency, or low frequency noise they block out? Or would you say it's fairly universal from that perspective?
Also what should I be looking at cost- wise? Does about £2,500 seem about right for a single medium- size bay made of 3 windows?
Thanks!
1) They look ace
Thanks!
I'd be quite chuffed if I got something really nice for £1250.
