- 22 Apr 2011
- Nottingham
Looks good, Will pick up a 1080
The sheer clockspeed of the thing seem to be masking some of its downsides imo. It'll be interesting to see a good solid review or 2!!
Well considering everyone is saying pascal is just an improved maxwell and considering a Titan X is rated at 6.3 Tflops, 9 Tflops on the new nvidia card is pretty damn good.
A TitanX is 6.3 TFlops at stock speed of around 1000MHz but overclock it to 1500MHz and the Tflops are effectively 9.15.
The 1080 is running at over 1600MHz to get 9 Tflops. What does that say about the Pascal architecture?
A 1080 runs the new Doom at 120-200fps @ 1080p via Vulcan.
That it is quite impressive, considering it only needs 2540 cores to do it and only has a tdp of 180w.
Also, Nvidia have already showed one doing 2.1ghz running very cool and on air.
Spot on. From what I have read, 2Ghz is easy and a 980Ti needs to run at 2Ghz to beat the 1080. Colour me impressed.
that 2.1Ghz clock is more than likely reachable on only the founders edition, cherry-picked parts when running on air, if at all on normal parts.
They have more than likely made these founders editions because of manufacturing defects being higher than they expected. Considering the base clock is 1.6ghz to 1.8ghz boost.
When they do a refresh at some point, once yields improve, then the entire range will more than likely perform closer to that 2ghz on air.
Since why else would they make a founders edition like this? it is just cherry picking of parts, that is all. And i would not expect large numbers of these cards being available, considering GDDR5X goes into mass production when these parts launch.
The second benchmark we have is from FireStrike Extreme, which as you probably already know is rendered at 2560×1440 resolution. This is actually the first benchmark where you will see 1.860 GHz clock. In this scenario GTX 1080 is faster than typical overclocked GTX 980 Ti (~8700 points). However if we compare it GTX 980 Ti running at almost the same frequency (1.8GHz with LN2 cooling), GTX 1080 is actually much slower clock to clock (Link).
So on the 27th apparently the only card will be the founders edition? The other cards will be later and you will not be able to buy the normal reference edition or custom cards on the 27th?
Lol, if micron were already sampling to customers in March and planning mass production in "the summer", it obviously means they were already in risk production and ramping. There is going to be a single GPU on the market using it, they will obviously have enough supply to account for a single model.
It sounds like youve been drinking too much of the Charlie koolaid and still thinking that micron saying mass production "in summer" means they cant release a product with it, but this is obviously a wrong assumption
