Adding windows to Caselabs S5 panel
29 Dec 2014
The "North"
I recently purchased a Caselabs case but it only has ventilated side panels (Not my choice :)) so I was wondering if anyone knows the best way to add a windows (Preferably glass) to the case. I don't mind paying for services such as plasma cutters as I'm looking for the best possible finished product. :eek:
So are there any options or would it be better just to lump the $100 to have one imported, as always any help is appreciated :D
Parvum Systems could probably help you out :D
Yup.
But those guys are often really busy so u need to be patient, and their prices aren't cheap either, their plus side is that you can have some more choices of window shapes other than rectangle and they do offer smoked windows :)
If you were to buy from CL directly, you can shoot me an email since I'm forwarding a CL case w/ pedastal from the US directly :)
Yup.
To be honest I'm more bothered about just having the cut or window already done so I can get an actual glass panel fitted. I would buy directly from CL but there delivery is so damn expensive :D
Have you tried the German distributor for CL? They might work out cheaper due to being in the EU which removes import taxes etc
I had a look on their site but there was no information about just ordering side panels/parts. I'll send them an email anyway as it's worth a shot :)
