Mayhems Fluid question
What colour you after?
What RAD would you like to use?
What CPU would you like to use?
Are you after a Nano coolant or a plane see though Coolant?
What tubing are you going to use?
What LEDs / CCFLs are you going to use?
Not got that far waiting to see which block and rad makers allow your fluids without voiding the warranty before i decide on anything as I would like to use your fluids. Hense my original question ;) O and it would be the X1 pre made stuff I would be using.
Oky X1
So Rads
all colours of X1 =
XPSC
EK
Alphacool
Magicool
Mayhems
Darker colours =
XPSC
EK
Alphacool
Magicool
Mayhems
HWlabs
Do not use with any ThermalTake rads simply put .... there crap.
Blocks use any one you like :)
UV Leds - Avoid Alphacool / Phobya spend a little more and get decent Leds. Darkside are the best bar none.
Soft Tubing - Primochill or Mayhems (were cheaper and better according to users on the net but that is for you to decide)
Hard tubing = You have Glass, PTEG or Acrylic - use what ever you like.
If your building a high end system "Heater" speak up let us know and we will advise accordingly.
Hate Thermaltake they just copy everyone else with cheaper crapper materials. Thanks for you help, O one last thing are you still doing your radiators and arnt they preflushed??
Oky X1
<snip>
Sorry to drag up issues but just to clarify as you've said that Primochill tubing (which I happen not to like) is safe with X1. Is it just the XT1 that doesn't mix with Primochill and other PVC-based tubing and the X1 is ok?
Mayhems what about Primochill PrimoFlex LRT Advanced hose and using Alphacool fittings with your fluid?
Yeah was thinking of grabbing a bag of 50 bitspower o-rings to be on safe side thanks again.
Sorry got one more questions how is EK equipment res/rad/blocks/fittings ect with your fluid m8?
Mayhems make pastel coolant for EK. I've used an EK res, blocks and fittings with pastel for nearly 2 years and never had a single issue.
We now make coolant for quite a few companies and more are coming on board. How we cannot discuss whom we work for as there are NDA's in place.
Mayhems not only makes its own fluids but we are a OEM manufacturer for many more.
How come the lighter coloured X1 fluid isn't recommended for use with HWLabs radiators? I've got two HWLabs SR1 rads in use with X1 Yellow/Green, and there hasn't been any discolouration to speak of.
Is that ek-zmt tubing any good?
And are monsoon fittings that bad seem to see a lot of moaning about them but they look awsome lol?
sorry to bunk an old thread but is this just an issue with primochill clear tubing?
just ordered X1 to use with primochill black tubing and a friend just mentioned this thread
