280 - How does it hold up
12 Dec 2005
Was thinking about getting a cheap graphics card for around £100 and saw a 280 3gb come up for £70
Would it be able to run games at decent settings
if it's for an upgrade, wait untill june, new line from polaris should have something for you at £100, and if it doesnt, 2nd hand GPU prices will drop further, it's really not a good idea to buy now unless you dont have a gpu at all.
My 390x struggles with modern games at 1080p / 60fps with everything turned up. I reckon a 280 will be decent for 1080p on medium to high depending on the title.
The 390X struggles? Seems odd that it does. I gave my 7970 to a friend (same as a 280 right?) and he's pretty happy with it. Not eating all games @60fps, but still a good card, it was good value even back when I bought it.
It's a 7950 really, pre AMD renaming project. 280x is 7970.
They are OK cards, I hated 7970/7990 trifire, I would not recommend crossfire with it.
But it's GCN 1.0 so won't support Freesync. To me, this would be a deal breaker as Freesync/GSync are amazing.
Ah forgot about the difference between a 280 and 280x. 7970's were my first experience with Crossfire - aside from the 5970 which was kinda forced on whoever bought it. Good performance gains on some things, others weren't so hot.
If you don't mind turning down a few settings, its is quite capable.
I have a 7950 as backup card, and it ran games like GTA 5 fine on medium high.
Keep dreaming. Unless you play on 800x600 resolution.
What he said seems completely accurate. :confused:
Of course, there are more demanding games than Far Cry 4, but still.
