Looking for a case that will fit EK predator 360 up top
3 Jun 2007
Essex
Hi All.
Just putting a new system together and am going to be using an EK predator 360 RAD plus the GPU water block addon.
Struggling to find any info an cases these 360 rads will fit into base on the extra length due the pump being attached to the end of the rad.
Anyone got one and know what case it might fit into?
only other alternative is to get the 240 version but not sure that would be good enough for both CPU and GPU.
Hi All.
I know the 240 can fit in a Evolv mATX.
As long as you don't put both CPU and GPU in full stress load they should be fine.
Just watched a review and think that case will be perfect.
It is a Full size tower, but it's not as large as the Primo (if that makes sense...?)
The Luxe won;t take a 420. Just be careful if you want to put the Pred in push/pull. If you do then you'll need to mod the case to allow the pump and reservoir to get into the top fan area.
If you're just going with the fans as they come then you'll be fine. Just be careful on your mobo 4 pin power connectors - it can be a bit of a tight fit.
The Fractal S can take 420mm rads in the top.
Just got my hands on the case today, very very happy.
