Bang for buck is Scythe, I have a Mugen Max which was £40 and cools better than the Be Quiet TFU and Dark Rock 2 before it
Scythe Kotetsu is even bigger bang for buck and cheaper
Thanks guys.
I am considering the Noctua NH-D15, seems a good shout?
Anything better value/performance wise?
The sealed loop AIO coolers seem overpriced to me?
I do not agree. The D14 performance is near identical to D15 with same fans, and even stock it is only 2-3c less at most .. hardly a 'decent improvement' in my book. Reviewers were kinda trapped into saying D15 is better than D14 to stay on Noctua's 'free test sample side'. Sad, but that's now it works.Yes the Noctua NH-D15 is supposed to be a decent improvement on the D14 and one of the top high end air coolers. You might also want to look at the Alpenfohn Olymp as it's in the same price bracket as the Noctua, which I can vouch for being quiet, sturdy, relatively easy to assemble, and provides plenty of cooling ability:
https://www.overclockers.co.uk/alpe...h-performance-cpu-cooler-140mm-hs-054-al.html
From what I've been able to find out the Olymp is best value. Next would be PH-TC14PE, NH-D15, Silver Arrow IB-E or SB-E, Dark Rock Pro 3, R2 Ultimate or Universal, etc. All have near identical performance except DRP3 which is quieter but a couple degrees warmer to be quieter. They are all so close it's pretty much which one you like the looks of best in your price range. Don't let your money burn a hole in your pocket. Only spend what you need to and save the rest.So, if a budget of £70, what would be the best choice?
I want to push this 4770K as far as it will go.
Thanks.
