Copper pipe.. Advice?
Not used the Kwix tool personally, but I've read very favourable comments in and around the ole interwebz on both computer mod blogs and plumbing forums.
I'm not too informed on the various copper pipe formats and treatments, so all I can say is hit up Google and see what comes up - you'll know better than I what's what :D
OK cool cheers. I was just going to run the copper through a hole the same diameter in a block of wood to straighten it. Think I may check out some videos of it
I think you are going to need one for 12mm, certainly the spring that goes inside while bending. You can polish the pipe up and then spray it with laquer to keep it shiny.
Copper pipe is easy enough to polish up all you need is the right stuff to do it. Someone did a build log here in which he finished off by giving the copper pipe a mirror finish and it looks great.
