I only had a quick Google, but are you sure?
https://www.barclaycard.co.uk/personal/credit-cards/using-contactless
and http://www.bbc.co.uk/news/business-34110348
I tried AP at lunch today and it failed. Virgin Atlantic Visa card (MBNA) on my OnePlus One. Didn't come up with a message or anythingUsed the same card manually instead, no problems.
The current contactless limit is £30 but at some retailers you can use Android Contactless Mobile to pay up to £100 by entering your PIN (the one you use with your card).
On the list of supported banks, my bank is on it as MasterCard + visa : debit + credit card but is "visa electron" not counted? Every time I try to add my card it just says not supported.
Ah that makes sense. If it's PIN verified then who cares!https://www.barclaycard.co.uk/personal/customer/contactless-mobile
You need to use it through their app![]()
Visa electron is different to Visa debit, tbh I thought all banks had phased them out because they were so limited.
I thought electron cards had long gone as well.
I didn't actually. I thought we established you didn't need to, but perhaps I'll try that next timeDid you unlock your phone before you tried to pay?
I have used it twice so far. First time got an error so unlocked my phone and it went through.
I'm a bit disappointed if all it does with store cards is display them so you can scan them as normal, I was hoping you could just tap once and it would both charge you and register your card, maybe something for the future.
Its a shame it doesnt auto send the card details with the payment details, surely its something they could do.
As it is its literally a photo of your card.
Well just tested it and worked perfect![]()
Root WORKS? how?
i tried on my rooted device and it wouldnt let me add and use a card
Small shops such as news agents and convenience stores just about take cards and use antiquated equipment. I do not suspect they will be investing any time soon.
All PDQ terminals I've seen have a swipe function for when chip and pin isn't working. So yeah Samsung Pay will effectively work anywhere with a card machine to pay for goods.
doesn't work for hsbc bank account cards btw
Doesn't work on some types of HSBC (legacy stuff) is what HSBC are saying. If you have a silver / orange card / the other high cards you're fine.How so? Mine is setup after a call to HSBC.
Not tested yet but I don't see anything to indicate it wouldn't work.
