Lovac is an awesome gun, probably best in game.....
Tonight at 1am I believe![]()
Mobile cover should be removed from the game.
I now know why in DZ some players hardly take any damage..........
Unlimited Mobile Cover Buff "The Division Damage Build Glitch"
https://www.youtube.com/watch?v=VetpCFBjlMc
Me neither (see above).
LOL that'd be mental!
FL cm tonight and DZ?
You're being sarcastic, right?
You are correct, sirTactical AUG A3P 204 blueprint please.
So sky HM only, cm will follow a week later. Okay, farming time! Really excited about this one!
if anyone is on at 1am could they have a scout please![]()
I think it's good they are delaying CM Sky. It means that all the inevitable glitches and exploits can come out in the open and they can fix them before any major cheesing takes place.
Damn right man. FL CM, Daily CM, DZ
Sky HM is good, it means if there is a cheesed method, the people cant get the highest gear - smart move, learning from their mistakes.
I will take screenshots and post stuff up about then![]()
Rather than scouting vendors, why not have a look at Arekkz YouTube channel Neil? He's always quick.
I am doing some overtime at work tonight but got one more character to do to get another 240 piece gear set, so should be back later and happy to do another CM FL if anyone is about when I get back (hopefully around 11:30 ish).
true, i wont be on until at least 9am after the refresh so if anyone wants to post the best bits if they're online then great otherwise i'll check the vid.
