MSI GTX 970 Red vs Silver
11 May 2012
Redcar
Is there any difference between the MSI GTX 970 GAMING Twin Frozr 5 with silver dragon on the box and the MSI GTX 970 GAMING with the red dragon on the box?
Never seen a MSI Gaming 970 Twin Frozr with a white dragon on the box. Only have seen a MSI Armor 2X 970 with a silver tiger on the box, which has lower boost clocks and generally a more budget model.
Pictures added to first post. Only different I can seam to find is the silver boxed MSI GTX 970 has the Twin Frozr 5 advertised on it. Can these two cards be put together in SLI.
I bought mine it came with the Silver dragon box. Just the standard Twinfroz gaming card. Not seen the red box one, but quick search of google images shows its not a photoshop error cause someone actually has a real red box one. Don't see what difference is either. :\
From the white one in the bottom left looks like it came with something free in the box on top of the usual offering. So probably that + a small revision or something.
Almost certainly just a small revision to the card, or even nothing more than a packaging change for whatever reason. Even the hideous lime green one is the same card underneath (albeit with a backplate).
:o
