- 28 May 2007
You really want to keep temps below 80c at these voltage levels, the lower the better. Put on some headphones and forget about the noise, that's what i used do with my 290X reference cards.![]()
Only had experience of my two pcs+ 290's which can handle a lot more volts on the stock profile. Best i had was 1220 core and 1500mhz at 200mv. I did run 100% fan for this run though. That card was better than my current one though which is not so stable. The temps are as good though. The Pcs+ cooler is among the best though.
. Personally I found +50% PL wasn't needed on 4 differing Hawaii cards I owned / OC'd, generally a ~10% increase was enough (OCs upto 1150/1575 tested).
