- 25 Nov 2015
also, if it happens again, use isopropyl alcohol to clean any electrical parts - it will be fine as long as you make sure they're dry before any current goes through them - coke is very corrosive so should be cleaned off as quickly as possible
(for a keyboard I'd be tempted to run water through it - unplugged - to clean out the coke and then dry thoroughly, a cool/warmish hairdryer would help - needs to be absolutely dry before using again)
