22 May 2016 at 17:02 #1 Edward78 Edward78 Soldato Joined 19 Oct 2002 Posts 5,780 Mate 1.12.0 Mint 17.3, is there any way to see why it disconnects?
22 May 2016 at 20:53 #2 lamboman lamboman Soldato Joined 7 Apr 2008 Posts 2,655 Yet another ambiguous Edward78 thread.
23 May 2016 at 04:39 #3 Edward78 Edward78 Soldato OP Joined 19 Oct 2002 Posts 5,780 lamboman said: Yet another ambiguous Edward78 thread. Click to expand... My claim to fame...
23 May 2016 at 07:36 #4 cutchy2k cutchy2k Associate Joined 6 Jul 2004 Posts 37 hmm does it say anything in dmesg at the time? check messages as well.
23 May 2016 at 13:50 #5 lamboman lamboman Soldato Joined 7 Apr 2008 Posts 2,655 Edward78 said: My claim to fame... Click to expand... Rather than posting this can't you instead inform us of: Kernel version (uname -r) Network interface type and model (you haven't even mentioned whether this is wireless or wired) Driver version for aforementioned adaptor What exactly happens when the disconnect occurs (does the device vanish or is it just a Wi-Fi disconnect but the adaptor is otherwise all good)? Do a site survey on both the router and desktop side to determine whether noisy channels are an issue.
23 May 2016 at 14:52 #6 bledd bledd Don Joined 21 Oct 2002 Posts 46,842 Location Parts Unknown Ethernet / powerline / wifi? Throw us a bone.
23 May 2016 at 20:07 #7 Edward78 Edward78 Soldato OP Joined 19 Oct 2002 Posts 5,780 Wired, Ethernet... Kernel 3.19.0-32-generic... Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 06) It discoes then reconnects... (no errors or anything)
23 May 2016 at 22:38 #8 Tom B Tom B Associate Joined 20 Oct 2007 Posts 779 How frequently? Is there a pattern? E.g. every hour, day?
24 May 2016 at 04:45 #9 Edward78 Edward78 Soldato OP Joined 19 Oct 2002 Posts 5,780 Tom B said: How frequently? Is there a pattern? E.g. every hour, day? Click to expand... No pattern, just twice yesterdy only for maybe a second... Maybe it was nothing, but it was odd..
24 May 2016 at 14:56 #10 kkelly kkelly Soldato Joined 8 Oct 2003 Posts 2,899 Location Glasgow Is the cable seated properly or cut anywhere ?
24 May 2016 at 16:18 #11 Edward78 Edward78 Soldato OP Joined 19 Oct 2002 Posts 5,780 kkelly said: Is the cable seated properly or cut anywhere ? Click to expand... Yes, I am sure... Maybe it was just a odd hiccup...
